[GRASS-dev] Test suite for GRASS - proposal, discussion welcome
Moritz Lennert mlennert at club.worldonline.be
Thu Jun 9 06:21:27 EDT 2011
On 09/06/11 10:01, Glynn Clements wrote:
> Soeren Gebbert wrote:
>> v.random output=random_points n=100
>> v.info -t random_points>  result
> If the framework understands vector maps, it shouldn't be necessary to
> use v.info; it should be able to compare the random_points map to
> random_points.ref.
But how to compare two randomly generated maps ? Unless the system is
not really random, the maps _should_ be different.
Moritz
