[GRASS-dev] Test suite for GRASS - proposal, discussion welcome
Soeren Gebbert soerengebbert at googlemail.com
Thu Jun 9 06:59:21 EDT 2011
Thats why I compare the topology information and not the
position/coordinates. In any cases 100 points must be generated.
Best
Soeren
Am 09.06.2011 12:21 schrieb "Moritz Lennert" <mlennert at club.worldonline.be>:
> On 09/06/11 10:01, Glynn Clements wrote:
>> Soeren Gebbert wrote:
>>> v.random output=random_points n=100
>>> v.info -t random_points> result
>> If the framework understands vector maps, it shouldn't be necessary to
>> use v.info; it should be able to compare the random_points map to
>> random_points.ref.
> But how to compare two randomly generated maps ? Unless the system is
> not really random, the maps _should_ be different.
> Moritz
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20110609/1bb1a112/attachment.html
