[GRASS-dev] Weekly reports #2 wxNviz
Moritz Lennert mlennert at club.worldonline.be
Fri Jun 10 09:34:57 EDT 2011
On 10/06/11 15:03, Anna Kratochvílová wrote:
>> ------------ Původní zpráva ------------
>> Od: Moritz Lennert <mlennert at club.worldonline.be>
>> Předmět: Re: [GRASS-dev] Weekly reports #2 wxNviz
>> Datum: 10.6.2011 14:48:44
>> On 10/06/11 14:02, Anna Kratochvílová wrote:
>> > Hi,
>> > 1) What do I have completed this week?
>> > I changed the layout of view page. I added cutting planes
>> functionality, I'm
>> considering
>> > changing the XY control, but I'm not sure how it should look like yet.
>> Thank you for the great work. I just updated my source and reompiled
>> and trying to launch 3d view immediately crashes the entire GUI,
>> without any error message on the console. I tried with export
>> WX_DEBUG=5, but still not message. Any hints how I could debug this to
>> get some idea why this is happening ?
>> Moritz
> Sorry, I have no idea what's happening. What platform do you use and
> which data have you loaded?
> By me everything is OK. I tried it on two computers (both Ubuntu).
I'm running this on Debian stable, with wx 2.8.10.1. I just noticed that
I have a similar problem with the wxgui digitizer: launch digitization
of a new map, select points, click to digitize point -> crash. Same with
lines: the crash occurs when I right-click to finish the line.
But, at this stage, I'm not looking for a solution (obviously if someone
has one off the hand, perfect), but for a way to debug this with
meaningful messages instead of a silent crash without any visible trace...
Moritz
