[GRASS-dev] Installing own Python script
Luca Delucchi lucadeluge at gmail.com
Mon Jun 13 13:08:46 EDT 2011
2011/6/13 Martin Landa <landa.martin at gmail.com>:
> Hi,
> 2011/6/1 Glynn Clements <glynn at gclements.plus.com>:
>>> > The per-module "install" target (which doesn't exist for scripts at
>>> > present) copies a single module (along with its manual page in HTML
>>> > and man formats) from the dist.<arch> directory to the installation
>>> > directory.
>>> > AFAICT, this is only useful if you're pushing your changes into the
>>> > installed version so frequently that having to do a full "make install"
>>> > from the top level each time would actually be a problem.
>>> Which could be interesting when developing that module/script?
>> If you're developing, you should be running GRASS from the staging
>> directory rather than using an installed version.
>> Apart from convenience, leaving the installed version alone means that
>> you can compare the behaviour of the modified version to the installed
>> version.
>> FWIW, the only time I run "make install" is if I've been working on
>> the Makefiles and I want to check that "make install" still works.
> I think that there should the per-script "install" target. At least
> for g.extension. Currently, g.extension fails with error.
> Installing 'r.threshold'...
> make: *** No rule to make target `install'.  Stop.
> WARNING: Installation failed, sorry. Please check above error messages.
I have the same problem, but the command it was compiled and installed....
> Martin
regards
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
