[GRASS-dev] Re: sample dataset update
Helena Mitasova hmitaso at ncsu.edu
Mon Jun 20 11:34:55 EDT 2011
Markus,
I have a TODO list for data set update already as well as several data sets, so if you set up a wiki page,
I will put there what I have planned with the links to the data.
There are numerous excellent public data sets available that we can
add. The current data set's PERMANENT mapset should stay as is so that
old material such as GRASS book works, but the new data could be added as separate mapsets that people
can insert into the location, such as here:
http://courses.ncsu.edu/mea582/common/GIS_anal_grass/GIS_Anal_grgeomorph2.html
and/or  we can prepare a completely new location.
Helena
On Jun 20, 2011, at 11:15 AM, Markus Metz wrote:
> Hi all,
> we may want to think about an update of the sample datasets. I have
> recently updated the documentation of the v.net.* modules including
> examples and noticed that roads digitized as multilanes have wrong
> line directions, i.e. not matching drive directions. This makes
> assignment of different forward/backward costs impossible. The vector
> map roads in nc_spm_08 should also get a new layer with unique
> category values. The updated, correct examples are anything but
> intuitive and would be much shorter and simpler with already existing
> unique categories in roads at PERMANENT.
> Helena also mentioned the LiDAR-based DEM in nc_spm_08 which needs to
> be expanded. With the development of a test suite for G7, I am sure
> that there will be more requests for updates of the sample datasets.
> Time for a TODO list somewhere?
> Markus M
