[GRASS-dev] GRASS Make-system question
Soeren Gebbert soerengebbert at googlemail.com
Fri Jun 24 05:33:04 EDT 2011
Hello Glynn,
i face some Make-system problems while implementing r3.colors on top
of r.colors. Because i have no clue how the make system actually works
i am lost. I have modified the r.colors Makefile to handle now
different main files to build two binaries:
MODULE_TOPDIR = ../..
LIBES = $(G3DLIB) $(RASTERLIB) $(GISLIB)
DEPENDENCIES = $(G3DDEP) $(GISDEP) $(RASTERDEP)
PROGRAMS = r.colors r3.colors
r_colors_OBJS = raster_main.o edit_colors.o rules.o stats.o
r3_colors_OBJS = raster3d_main.o edit_colors.o rules.o stats.o
include $(MODULE_TOPDIR)/include/Make/Multi.make
default: multi
# Insert thumbnail previews
r.colors.tmp.html: $(HTMLSRC) thumbnails.py
	$(call htmldesc,$<,$@)
	sed 's!^<DD><b>\([a-z0-9.]*\)</b>:!<DD><img width="80" height="12"
src="Colortable_\1.png"> <b>\1</b>:!' "$@" > "$@.tmp"
	mv -f "$@.tmp" "$@"
	$(MAKE) thumbnails
thumbnails: $(BIN)/r.mapcalc$(EXE)
	-$(call run_grass, ./thumbnails.py)
$(BIN)/r.mapcalc$(EXE):
	$(MAKE) -C ../r.mapcalc
.PHONY: thumbnails
.INTERMEDIATE: r.colors.tmp.html
The source code compile well, but i broke the thumbnail preview
creation. Here the compilation report and error:
Makefile:17: warning: overriding commands for target `r.colors.tmp.html'
../../include/Make/Multi.make:30: warning: ignoring old commands for
test -d OBJ.x86_64-unknown-linux-gnu || mkdir -p OBJ.x86_64-unknown-linux-gnu
gcc  -ggdb -Wall -Werror-implicit-function-declaration -fno-common
-fopenmp   -I/home/soeren/src/grass7.0/grass_trunk/dist.x86_64-unknown-linux-gnu/include
 -D_FILE_OFFSET_BITS=64  -DPACKAGE=\""grassmods"\"
-o OBJ.x86_64-unknown-linux-gnu/raster_main.o -c raster_main.c
-o OBJ.x86_64-unknown-linux-gnu/edit_colors.o -c edit_colors.c
-o OBJ.x86_64-unknown-linux-gnu/rules.o -c rules.c
-o OBJ.x86_64-unknown-linux-gnu/stats.o -c stats.c
: && gcc -L/home/soeren/src/grass7.0/grass_trunk/dist.x86_64-unknown-linux-gnu/lib
-lgomp -Wl,--export-dynamic
-Wl,-rpath-link,/home/soeren/src/grass7.0/grass_trunk/dist.x86_64-unknown-linux-gnu/lib
  -o /home/soeren/src/grass7.0/grass_trunk/dist.x86_64-unknown-linux-gnu/bin/r.colors
OBJ.x86_64-unknown-linux-gnu/stats.o    -lgrass_g3d.7.0.svn
-lgrass_raster.7.0.svn -lgrass_gis.7.0.svn  -lm
-o OBJ.x86_64-unknown-linux-gnu/raster3d_main.o -c raster3d_main.c
  -o /home/soeren/src/grass7.0/grass_trunk/dist.x86_64-unknown-linux-gnu/bin/r3.colors
GISRC=/home/soeren/src/grass7.0/grass_trunk/dist.x86_64-unknown-linux-gnu/demolocation/.grassrc70
GISBASE=/home/soeren/src/grass7.0/grass_trunk/dist.x86_64-unknown-linux-gnu
PATH="/home/soeren/src/grass7.0/grass_trunk/dist.x86_64-unknown-linux-gnu/bin:$PATH"
PYTHONPATH="/home/soeren/src/grass7.0/grass_trunk/dist.x86_64-unknown-linux-gnu/etc/python:$PYTHONPATH"
LD_LIBRARY_PATH="/home/soeren/src/grass7.0/grass_trunk/dist.x86_64-unknown-linux-gnu/bin:/home/soeren/src/grass7.0/grass_trunk/dist.x86_64-unknown-linux-gnu/lib:/home/soeren/src/grass7.0/grass_trunk/dist.x86_64-unknown-linux-gnu/lib:/home/soeren/src/grass7.0/grass_trunk/dist.x86_64-unknown-linux-gnu/lib:/usr/local/lib/vtk-5.9:/usr/lib64/jvm/java-1.6.0-sun-1.6.0/jre/lib/amd64/xawt:/usr/local/lib:/home/soeren/src/grass7.0/grass_trunk/dist.x86_64-unknown-linux-gnu/lib:/usr/local/lib64/R/lib"
LC_ALL=C thumbnails.py --html-description < /dev/null | grep -v
'</body>\|</html>' > r.colors.tmp.html
/bin/sh: thumbnails.py: command not found
make: *** [r.colors.tmp.html] Error 1
Can you please give me a hint what i did wrong and how the Makefile
should look like?
Many thanks
Soeren
2011/6/23 Glynn Clements <glynn at gclements.plus.com>:
> Soeren Gebbert wrote:
>> >> Can anybody give me a hint how to solve this.
>> > Don't try to use quick hacks; do it properly. Either clone the file as
>> > e.g. main3.c or make it support both 2d and 3d at run-time.
>> Well, actually my intention was not a quick hack. I thought it would
>> be meaningful to use macros to reduce the appearance of cloned code
>> for easier code maintainability. I did not know that using macros to
>> decide at compile time the behavior of a program is a hack at all.
> It's not the use of macros that's a hack (there's plenty of code with
> conditional sections), but building multiple, distinct object files
> from the same source file.
> With one exception[1], the GRASS 7.0 build system relies entirely upon
> the '%.o: %.c' (etc) pattern rules in Compile.make. This ensures that
> any changes to those rules affect everything; there's no need to hunt
> down special cases which need to be changed separately (and, in
> practice, are likely to be overlooked).
> [1] macosx/app/Makefile has an explicit rule for "main.o: main.m".
>> I changed the code of r/r3.color.out to meet your guideline.
>> I have to rethink the r/r3.colors approach to meet your guideline too,
>> but to also reducing cloned code. I am not a fan of cloned code and
>> modules with mixed behavior (raster and raster3d support) with the
>> need adding scripts to hide there complexity:
> If you want distinct modules, make each #ifdef'd chunk into a separate
> function, then move those functions into separate source files, one
> for 2d and one for 3d.
