[GRASS-dev] Re: [GRASS-SVN] r46717 - grass/branches/releasebranch_6_4/scripts/v.build.all
Markus Metz markus.metz.giswork at googlemail.com
Tue Jun 28 03:16:33 EDT 2011
On Tue, Jun 28, 2011 at 1:05 AM, Hamish <hamish_b at yahoo.com> wrote:
> MMetz:
>> >     CMD="v.build map=${VECT}@${MAPSET}"
>> > -    g.message "$CMD"
>> > +    g.message message="$CMD"
>> >     $CMD
>> >  done
> MNeteler:
>> ... is this a needed change?
>> Most are without this parameter...
> Needed in this case because the string contains a '=', which
> confuses the parser.
.. and resulted in a fatal error
> Hamish
> ps- those curly brackets do nothing..
also no harm
Markus M
