[GRASS-dev] Re: [SoC] Weekly reports #4 wxNviz
Maris Nartiss maris.gis at gmail.com
Wed Jun 29 12:16:05 EDT 2011
Hello,
adding coordinates can be a tricky task, as there's no single
"de-facto" OpenGL text rendering library and such one is required to
not reinvent the wheel. I was playing a bit around with some of them
last spring, still had not enough time to find fast to implement and
easy solution (and I'm not an OpenGL coder). We will have to decide
which one to use to get text into NVIZ scene (FTGL?).
If getting some text to be displayed is not that hard task, still I
would strongly suggest to go for more. And by more I mean - unicode
and TTF (or similar) font support for any text rendering to allow
later on work on vector labels, user placed labels and signs.
Just my 0.02 and no code :(
Maris.
2011/6/29 Helena Mitasova <hmitaso at ncsu.edu>:
> Anna,
> I just tested the latest updates and everything (light sphere, fringe, constant elevation, cutting planes) works great on Mac.
> Looking at the wxnviz wiki http://grass.osgeo.org/wiki/WxNviz it seems that you have now resolved all known issues
> (and it is only june!) so you can cross them out. Lot of the features (such as draping color, changing elevation of the constant plane, etc.)
> are now much easier to use and faster as well.
> I still need to test the volumes and the decorations that you might not have looked at yet.
> One thing that came to mind when I was doing some figures for publications was the possibility to add ticks with
> coordinates to the fringe x,y,z axes - I am wondering how difficult it would be.
> Helena
> On Jun 24, 2011, at 10:48 AM, Anna Kratochvílová wrote:
>> Hi,
>> 1) What do I have completed this week?
>> I added new nviz features in workspace (light, view, constant planes). It took quite a lot of time to make it work properly.
>> I will add other features continuously.
>> 2) What am I going to achieve for next week?
>> It seems that thematic points will be postponed. So I will follow the project plan (update nviz_cmd) and I will keep fixing bugs.
>> 3) Is there any blocking issue?
>> No
>> Anna
>> SoC mailing list
>> SoC at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/soc
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
