[GRASS-dev] [GRASS GIS] #1289: wingrass65 - Vector digitizer not available: Reason: xdr not found
GRASS GIS trac at osgeo.org
Wed Mar 2 04:41:49 EST 2011
 Reporter:  hellik                       |       Owner:  grass-dev@…
     Type:  defect                       |      Status:  new
 Priority:  critical                     |   Milestone:  6.5.0
Component:  wxGUI                        |     Version:  svn-develbranch6
 Keywords:  wingrass, vector, digitizer  |    Platform:  MSWindows Vista
      Cpu:  x86-32                       |
 tested with a self compiled wingrass65 at r45511
 message in the wxgui at startup:
 3D view mode not available
 Reason: xdr not found.
 Note that the wxGUI's 3D view mode is currently disabled on
 MS Windows (hopefully this will be fixed soon). Please keep
 an eye out for updated versions of GRASS. In the meantime
 you can use "NVIZ" from the File menu.
 Note that the wxGUI's vector digitizer is currently disabled
 (hopefully this will be fixed soon). Please keep an eye out
 for updated versions of GRASS. In the meantime you can use
 "v.digit" from the Develop Vector menu.
 from package.log
 checking for library containing cuserid... no
 checking for xdrmem_create... no
 checking for xdrmem_create in -lsun... no
 checking for xdrmem_create in -lnsl... no
 checking for xdrmem_create in -lrpclib... no
 checking for xdrmem_create in -lxdr... yes
 checking for asprintf... no
 checking for atan... yes
 if I add a vector in the mapdisplay and then open the table attribute
 manager, dbf.exe is crashing.
 Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1289>
