[GRASS-dev] Re: [GRASS GIS] #1053: After abort command v.surf.rst from wxGUI vector output of devation (devi) couldn´t be removed, or overwrited
GRASS GIS trac at osgeo.org
Thu Mar 3 02:40:15 EST 2011
 Reporter:  jeleniste                    |       Owner:  grass-dev@…
     Type:  defect                       |      Status:  new
 Priority:  normal                       |   Milestone:  6.4.0
Component:  Vector                       |     Version:  6.4.0 RCs
 Keywords:  v.surf.rst, wxgui, wingrass  |    Platform:  MSWindows XP
      Cpu:  x86-32                       |
Comment(by neteler):
 A solution might ge to use Vect_delete() immediately before the
 G_fatal_error() call(s)
 in order to get rid of the devi map while closing the process.
Ticket URL: <https://trac.osgeo.org/grass/ticket/1053#comment:4>
