[GRASS-dev] Re: [GRASS GIS] #226: WinGRASS fails to create .gislock opening a mapset
GRASS GIS trac at osgeo.org
Thu Mar 3 10:44:34 EST 2011
 Reporter:  msieczka        |       Owner:  grass-dev@…
     Type:  defect          |      Status:  new
 Priority:  major           |   Milestone:  6.4.0
Component:  Default         |     Version:  svn-develbranch6
 Keywords:  wingrass, qgis  |    Platform:  MSWindows XP
      Cpu:  All             |
Comment(by glynn):
 Replying to [comment:6 hamish]:
 > no idea if anyone is trying multi-user over SMB in the classroom,
 otherwise the main danger on Windows is trying to restart a session when
 you've already got the same one minimized. (?)
 Which isn't much of a danger. The biggest issue with concurrent use is
 that the WIND file is per mapset, not per session. The mere existence of
 another session with the same mapset isn't an issue; it only becomes an
 issue if both sessions are actually running commands.
Ticket URL: <https://trac.osgeo.org/grass/ticket/226#comment:7>
