[GRASS-dev] Re: [GRASS GIS] #1275: HGT Import
GRASS GIS trac at osgeo.org
Sat Mar 5 01:27:24 EST 2011
#1275: HGT Import
 Reporter:  MartinOver           |       Owner:  grass-dev@…
     Type:  defect               |      Status:  new
 Priority:  normal               |   Milestone:  6.4.1
Component:  Packaging            |     Version:  6.4.0
 Keywords:  r.in.srtm, wingrass  |    Platform:  MSWindows XP
      Cpu:  All                  |
Comment(by hamish):
 > Replying to [comment:2 hamish]:
 > > easy work around: unzip it yourself before running the program.
 Replying to [comment:3 martinover]:
 > The workaround does not work
 I am a bit surprised by that, it should.
 > The Problem is that I can import the Data in the standalone
 > installation but can not export the dataset (empty image) or
 > work with the dataset (for example wirth the raster calculator).
 after import you need to change the working ("computational") region to
 match the bounds of the map. Run "g.region rast=your_map".
 > In the osgeo4w installation I can´t even import the dataset.
 exact error messages are needed. (assuming it's not the same unzip one,
 which should only be shown if you feed it a .zip file)
 > Is it possible for you to import and export the
 > hgt files: http://dds.cr.usgs.gov/srtm/version2_1/SRTM3/Eurasia/
 (todo)
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1275#comment:4>
