[GRASS-dev] Re: [GRASS GIS] #1271: osgeo4w patch update
GRASS GIS trac at osgeo.org
Sat Mar 5 09:35:18 EST 2011
 Reporter:  jef          |       Owner:  grass-dev@…
     Type:  enhancement  |      Status:  new
 Priority:  normal       |   Milestone:  6.4.1
Component:  Packaging    |     Version:  svn-releasebranch64
 Keywords:  wingrass     |    Platform:  MSWindows Vista
      Cpu:  Unspecified  |
Changes (by martinl):
  * component:  Default => Packaging
Comment:
 Replying to [comment:21 jef]:
 > > btw, in r45561 `env.bat` moved to `c:\osgeo4w\etc\ini\grass65.bat`
 > That way multiple GRASS version can't coexist.
 > The files in etc/ini are general versions - which should only be used
 when there is only one version.  These are sources from o4w_env.bat, which
 is used by several start files in bin.
 > For packages in multiple version there are batch files in bin (GDAL for
 example) that are either invoked manually from the shell to activate a
 specific version (like gdal17.bat) or implictely from the start batch file
 of the other software (e.g. grass.bat currently uses gdal17.bat and qgis-
 dev.bat uses grass-env.bat).
 right, revered in r45564.
 > The patch puts init.bat.tmpl into bin/grass$POSTFIX-env.bat.tmpl, which
 is updated with the actual install path on install by
 etc/postinstall/grass$POSTFIX.bat (from postinstall.bat) and sourced from
 grass$POSTFIX.bat (from grass.bat.tmpl) which then invokes the actual
 init.bat in apps/grass-$POSTFIX/etc/init.bat.
 `init.bat.tmpl` has been renamed to `env.bat.tmpl` and it's currently
 installed into `$GISBASE\etc\env.bat`. There are only two files installed
 into `c:\osgeo4w\bin`
  * `grass$POSTFIX` by `make install` (shell script)
  * `grass$POSTFIX.bat` by `package.sh` (bat script)
Ticket URL: <https://trac.osgeo.org/grass/ticket/1271#comment:22>
