[GRASS-dev] Re: [GRASS GIS] #1266: d.vect has problems
GRASS GIS trac at osgeo.org
Mon Mar 7 03:46:45 EST 2011
  Reporter:  akbgf    |       Owner:  grass-dev@…
      Type:  defect   |      Status:  reopened
  Priority:  normal   |   Milestone:  7.0.0
 Component:  Display  |     Version:  svn-trunk
Resolution:           |    Keywords:  d.vect
  Platform:  Linux    |         Cpu:  x86-32
Comment(by akbgf):
 I have tested r45185, r45214, r45303, r45357, r45362, r45396, r45405,
 r45592. [[BR]]
 The problem is still there. Even if I change in the same d.vector window
 the vector map to another and remove all selection criteria (category and
 where conditions), this one is also non-visible. The only way to get it
 visible is to close the d.vector window and add in the Layer Manager a new
 vector layer. I can use selection criteria in r44607 which I am still
 using.[[BR]]
 Andres Kuusk
Ticket URL: <http://trac.osgeo.org/grass/ticket/1266#comment:4>
