[GRASS-dev] ctypes naming convention - grass.py
Martin Landa landa.martin at gmail.com
Tue Mar 8 05:37:40 EST 2011
2011/3/8 Hamish <hamish_b at yahoo.com>:
>> is there any special reason why libgis is named in ctypes
>> interface as grass.py [1]. I would vote for gis.py to keep
>> consistency in names.
> fwiw, on a system with many python libraries available, I'd guess
> that "import grass" was a lot more specific than "import gis".
you are always importing this module from the `grass` packages, so
import grass.lib.grass as grass
or
from grass.lib import grass
So I really don't see any problem here. Moreover `grass` makes
impression that it's some generic module for GRASS Python API, which
is not true. So it's confusing at the end.
import grass.lib.gis as gis
or
from grass.lib import gis
seems to be quite OK for me.
> I'd assume most people have more than one GIS software installed,
> and many GIS software do python these days, so would the change
> lead to conflicts? or would it just be exposed internally?
You can always use
from grass.lib import gis as libgis
Current
`grass.lib.grass` seems to be weird to me, braking naming convention,
confusing for the user. What about
import grass.lib.vector
I would assume that there can me tons of packages with name 'vector'.
>From this point  of view 'gis' as package name is less common ;-)
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
