[GRASS-dev] Re: [GRASS GIS] #1301: wingrass: db.in.ogr fails to load .csv file
GRASS GIS trac at osgeo.org
Wed Mar 9 00:06:46 EST 2011
 Reporter:  morrisxs09  |       Owner:  grass-dev@…
     Type:  defect      |      Status:  new
 Priority:  normal      |   Milestone:  6.4.1
Component:  Database    |     Version:  svn-releasebranch64
 Keywords:  wingrass    |    Platform:  MSWindows XP
      Cpu:  x86-32      |
Comment(by morrisxs09):
 I'm using the winGRASS gui i.e.
 File > Import database table > Multiple import formats using OGR
 Window pops up
 . On the "Required" tab, select "Browse" button on the "Table file to be
 imported or DB connection string" to navigate to .csv file and select
 required file to load.
 . Enter any other required fields on the other tabs
 . Press "Run"
 error occurs
 Are you suggesting quotes have to be added after the "Table file to be
 imported or DB connection string" field is populated?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1301#comment:2>
