[GRASS-dev] Re: [GRASS GIS] #757: WinGRASS: GUI window from cmd line
GRASS GIS trac at osgeo.org
Wed Mar 9 16:50:49 EST 2011
 Reporter:  silviap      |       Owner:  grass-dev@…
     Type:  task         |      Status:  new
 Priority:  trivial      |   Milestone:  6.4.0
Component:  wxGUI        |     Version:  6.4.0 RCs
 Keywords:  wingrass     |    Platform:  MSWindows XP
      Cpu:  Unspecified  |
Comment(by hellik):
 Replying to [comment:8 silviap]:
 > Replying to [comment:7 cnielsen]:
 > > A bit of misunderstanding here. GRASS is starting fine, but once open
 the dialogs of individual modules aren't opening when they are typed into
 the shell. Instead if you type {{{ r.walk }}} or whatever, the module's
 ascii help text is output to the shell (as required arguments are missing,
 ie. output) instead of opening a dialog window where the arguments may be
 entered.
 > > -Colin
 > GRASS is starting fine, thank you for explaining it better and sorry for
 creating the misunderstanding.
 closing the ticket?
Ticket URL: <http://trac.osgeo.org/grass/ticket/757#comment:11>
