[GRASS-dev] Re: [GRASS GIS] #1019: winGRASS: 'layer manager' window hidden by 'mapdisplay' windows
GRASS GIS trac at osgeo.org
Wed Mar 9 16:53:51 EST 2011
 Reporter:  neteler      |       Owner:  grass-dev@…
     Type:  enhancement  |      Status:  new
 Priority:  normal       |   Milestone:  6.4.0
Component:  wxGUI        |     Version:  svn-releasebranch64
 Keywords:  wingrass     |    Platform:  MSWindows 7
      Cpu:  Unspecified  |
Comment(by hellik):
 Replying to [ticket:1019 neteler]:
 > The stacking order of the 'layer manager' window and the 'map display'
 windows are suboptimal: Currently on XP, Windows7 (more?) the wxGUI opens
 and the layer manager window is in the background which the empty map
 display overlaying it and hiding the menu.
 > Related answer from ML:
 > On Wed, Jan 20, 2010 at 7:41 AM, Glynn Clements wrote:
 > > I don't think that it's a bug as such, just that you don't have
 > > precise guarantees as to the order in which some things happen.
 > > You may be able to solve the issue by adding an idle handler, and
 > > moving the layer manager to the top the first time that it triggers.
 > > Alternatively, wait for the first EVT_PAINT event on the display
 > > window, and move the layer manager to the top at that point. EVT_PAINT
 > > shouldn't occur until the window has been realised.
 > Idea: Perhaps the map display could be opened, then sleep some
 nanoseconds,
 > then open the menu to enforce it to open '''over''' (after) the empty
 map display?
 > Markus
 still an issue, closing the ticket?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1019#comment:2>
