[GRASS-dev] Re: [GRASS GIS] #984: v.out.ogr to MySQL does not work propely
GRASS GIS trac at osgeo.org
Wed Mar 9 17:31:30 EST 2011
 Reporter:  pablotcarreira              |       Owner:  grass-dev@…
     Type:  defect                      |      Status:  new
 Priority:  normal                      |   Milestone:  6.4.0
Component:  Vector                      |     Version:  unspecified
 Keywords:  wingrass, v.out.ogr, mysql  |    Platform:  MSWindows XP
      Cpu:  x86-32                      |
Comment(by hellik):
 Replying to [ticket:984 pablotcarreira]:
 > With OSGeo4W version
 > When try v.out.ogr some vectors to Mysql
 > I got the following problem:
 > ERROR 1: MySQL error message:Duplicate entry '1' for key 'OGR_FID'
 > For every vector it try to use the same OGR_FID and at the end It
 exports
 > only the first vector becouse the other has duplicated FID.
 > the command is the following:
 > v.out.ogr --verbose input=areas_vector at geral type=area
 dsn=MYSQL:geobase,user=root,password=xxxxx,host=localhost format=MySQL
 olayer=teste3 -c lco=spatial_index=no
 > I had sent a message to gdal-devel and here is the answer:
 > >>This could happen if you pass to CreateFeature() features that have
 the same
 > >>id set by OGRFeature::SetFID() as being 1... Check with
 OGRFeature::GetFID()
 > >>what you pass to CreateFeature().
 > >>Even
 > With ogr2ogr utilitie the GRASS->MySQL works fine.
 closing the ticket?
Ticket URL: <http://trac.osgeo.org/grass/ticket/984#comment:2>
