[GRASS-dev] Re: [GRASS GIS] #1307: wingrass: new wxgui dialog for v.in.ogr in windows7 does not show *.shp files
GRASS GIS trac at osgeo.org
Fri Mar 11 18:33:30 EST 2011
files
 Reporter:  marmai            |       Owner:  martinl
     Type:  defect            |      Status:  assigned
 Priority:  normal            |   Milestone:  6.4.1
Component:  wxGUI             |     Version:  6.4.1 RCs
 Keywords:  import, wingrass  |    Platform:  MSWindows 7
      Cpu:  Unspecified       |
Comment(by hamish):
 in all cases the file selector's extension type filter should offer a
 secondary option of "All files (*.*)" if it otherwise chooses one for you.
 It shouldn't lock users into its own limited assumptions about how files
 should be named.
 e.g. GeoTIFF often comes as .tiff or .geotiff; jpeg as .jpeg; GRIB format
 raster input is often as .grib or without extension, not just *.grb,
 *.GRB, etc.
 Nice to have it pre-filter, but hard-locking it to just a short list of
 pre-chosen extension choices (usually munged into 8.3 DOS extension
 limits) creates a road block which doesn't need to be there, so the user
 needs a way to bypass that if they need to.
 thanks,
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/1307#comment:7>
