[GRASS-dev] Re: [GRASS GIS] #1308: wingrass - dbf.exe-crash
GRASS GIS trac at osgeo.org
Tue Mar 15 12:47:17 EDT 2011
 Reporter:  hellik                     |       Owner:  grass-dev@…
     Type:  defect                     |      Status:  new
 Priority:  blocker                    |   Milestone:  6.4.1
Component:  Default                    |     Version:  svn-releasebranch64
 Keywords:  wingrass, dbf.exe, d.vect  |    Platform:  MSWindows Vista
      Cpu:  x86-32                     |
Comment(by martinl):
 Replying to [ticket:1308 hellik]:
 > some additional informations (delivered by DEUBUG=5 and windows-crash-
 informations:
 > D1/5: grass.script.core.start_command(): g.mlist -m type=vect
 > D1/5: grass.script.core.start_command(): v.db.connect -g
 map=lakes at PERMANENT fs=;
 > D1/5: grass.script.core.start_command(): db.describe -c table=lakes
 driver=dbf database=C:\gisdata\grassdata\nc_spm_08\PERMANENT\dbf\
 > GRASS 6.4>
 > GRASS 6.4> D1/5: grass.script.core.start_command(): d.vect --q
 map=lakes at PERMANENT type=point,area,face,centroid,line,boundary
 > D1/5: grass.script.core.start_command(): g.pnmcomp opacity=1.0
 mask=c:\users\syringia\appdata\local\temp\tmp5rhzes.pgm height=502
 width=782 background=255:255:255:255
 input=c:\users\syringia\appdata\local\temp\tmp5rhzes.ppm
 output=c:\users\syringia\appdata\local\temp\tmpo5cnsd.ppm
 > D1/5: grass.script.core.start_command(): g.findfile -n file=MASK
 element=cell
 it doesn't seem to be full debug output, I can see only debug messages
 produced by python library...
Ticket URL: <http://trac.osgeo.org/grass/ticket/1308#comment:9>
