[GRASS-dev] Re: [GRASS GIS] #1184: "d.vect display=attr" imply grass open process but doesn't close them.
GRASS GIS trac at osgeo.org
Wed Mar 16 17:31:47 EDT 2011
 Reporter:  met          |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  critical     |   Milestone:  6.4.1
Component:  wxGUI        |     Version:  6.4.0
 Keywords:  wingrass     |    Platform:  MSWindows XP
      Cpu:  Unspecified  |
Comment(by hellik):
 Replying to [comment:1 hamish]:
 > Hi,
 > I can reproduce this using a brand new nightly build of wingrass 6.4 and
 6.5 with the wxGUI and spearfish dataset.
 >  * ctrl-alt-del to open the process monitor, click the Image name column
 in the Processes tab to sort by process name.
 >  * in the wxgui layer manager add the roads vector map, then tick
 disp=attr and set attrcol to 'label' in the d.vect Labels tab.
 >  * then zoom, pan around and watch the number of cmd.exe and dbf.exe
 processes grow. exiting grass does not kill them, and they are not visible
 on the task bar.
 > in 6.4 it just leaves orphaned processes behind, in 6.5svn it is worse,
 using d.vect attrcol= locks the entire GUI and Windows XP taskbar until
 you type `exit` in the MSys rxvt terminal (which is still fully
 responsive).
 > cleanup: killing the dbf.exe processes makes the cmd.exe ones go away
 too.
 > Hamish
 still there in WinGRASS-6.4.SVN-r45671-1-Setup.exe
 Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1184#comment:2>
