[GRASS-dev] Re: [GRASS GIS] #1189: wingrass: 'g.region -l' fails
GRASS GIS trac at osgeo.org
Wed Mar 16 19:04:04 EDT 2011
 Reporter:  hamish              |       Owner:  grass-dev@…
     Type:  defect              |      Status:  new
 Priority:  critical            |   Milestone:  6.4.1
Component:  Packaging           |     Version:  svn-develbranch6
 Keywords:  wingrass, g.region  |    Platform:  MSWindows XP
      Cpu:  x86-32              |
Comment(by hamish):
 [spearfish]
 > WARNUNG: pj_transform() fehlgeschlagen: failed to load datum shift file
 ok, so perhaps a spaces in pathnames problem.
 look for the +nadgrids= filename from 'g.proj -p'.
 > maybe there's something wrong with the sample dataset?
 seeing that spearfish is the most-tested dataset out there, if there was a
 problem there I think we would have found it by now.
 another thing to try: 'g.region -d' before 'g.region -l'.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1189#comment:7>
