[GRASS-dev] Re: [GRASS GIS] #1189: wingrass: 'g.region -l' fails
GRASS GIS trac at osgeo.org
Thu Mar 17 16:26:37 EDT 2011
 Reporter:  hamish              |       Owner:  grass-dev@…
     Type:  defect              |      Status:  new
 Priority:  critical            |   Milestone:  6.4.1
Component:  Packaging           |     Version:  svn-develbranch6
 Keywords:  wingrass, g.region  |    Platform:  MSWindows XP
      Cpu:  x86-32              |
Comment(by hellik):
 Replying to [comment:7 hamish]:
 > [spearfish]
 > > WARNUNG: pj_transform() fehlgeschlagen: failed to load datum shift
 file
 > > maybe there's something wrong with the sample dataset?
 > seeing that spearfish is the most-tested dataset out there, if there was
 a problem there I think we would have found it by now.
 > another thing to try: 'g.region -d' before 'g.region -l'.
 tested by wingrass64, wingrass65, wingrass70
 -WinGRASS-6.4.SVN-r45671-1-Setup.exe
 GRASS 6.4> g.proj -p
 -PROJ_INFO-------------------------------------------------
 datum      : nad27
 nadgrids   : conus
 proj       : utm
 ellps      : clark66
 a          : 6378206.4000000004
 es         : 0.0067686580
 f          : 294.9786982000
 zone       : 13
 -PROJ_UNITS------------------------------------------------
 unit       : meter
 units      : meters
 meters     : 1.0
 GRASS 6.4> g.region -d
 GRASS 6.4> g.region -l
 WARNUNG: pj_transform() fehlgeschlagen: failed to load datum shift file
 FEHLER: Fehler in pj_do_proj (Projektion des Eingabekoordinatenpaars).
 -WinGRASS-6.5.SVN-r45672-1-Setup.exe
 GRASS 6.5> g.proj -p
 datum      : nad27
 nadgrids   : conus
 proj       : utm
 ellps      : clark66
 es         : 0.0067686580
 f          : 294.9786982000
 zone       : 13
 unit       : meter
 units      : meters
 meters     : 1.0
 GRASS 6.5> g.region -d
 GRASS 6.5> g.region -l
 GRASS 6.5>
 -WinGRASS-7.0.SVN-r45681-1-Setup.exe
 GRASS 7.0.svn> g.proj -p
 datum      : nad27
 nadgrids   : conus
 proj       : utm
 ellps      : clark66
 es         : 0.0067686580
 f          : 294.9786982000
 zone       : 13
 unit       : meter
 units      : meters
 meters     : 1.0
 GRASS 7.0.svn>
 GRASS 7.0.svn> g.region -d
 GRASS 7.0.svn> g.region -l
 GRASS 7.0.svn>
 > ok, so perhaps a spaces in pathnames problem.
 > look for the +nadgrids= filename from 'g.proj -p'.
 any other test out there to test if there is maybe another spaces-in-
 pathnames-problem?
 Helmut
Ticket URL: <https://trac.osgeo.org/grass/ticket/1189#comment:8>
