[GRASS-dev] [GRASS GIS] #1314: DebCheck QA: Common realloc mistake: nulled but not freed upon failure
GRASS GIS trac at osgeo.org
Fri Mar 18 02:44:12 EDT 2011
 Reporter:  hamish                   |       Owner:  grass-dev@…
     Type:  defect                   |      Status:  new
 Priority:  normal                   |   Milestone:  6.4.2
Component:  Compiling                |     Version:  6.4.0
 Keywords:  r.terraflow, v.label.sa  |    Platform:  Linux
      Cpu:  Unspecified              |
 Debian's run of the Cpp check tool automatically found a number of C-code
 errors (or potential errors) which need to be reviewed by hand. See grass-
 dev ML thread of 13 Jan 2011.
 about:
 ''Cppcheck is a command-line tool that tries to detect bugs that your
 C/C++ compiler doesn't see. It is versatile, and can check non-standard
 code including various compiler extensions, inline assembly code, etc. Its
 internal preprocessor can handle includes, macros, and several
 preprocessor commands. While Cppcheck is highly configurable, you can
 start using it just by giving it a path to the source code.''
  http://www.linuxjournal.com/content/daca-could-mean-less-bugs-debian
 the list of probably-bugs in the 6.4.0 C/C++ code:
   http://qa.debian.org/daca/cppcheck/squeeze/grass_6.4.0~rc6+42329-3.html
 CLI analysis program (not Debian specific):
   http://cppcheck.wiki.sourceforge.net
 I have split those 154 hits into 16 classes, and will report each class in
 an individual bug report.
 Run against releasebranch6_4 r42329 (including all patches up to, but not
 beyond, 6.4.0-final)
 This bug report is for: '''Common realloc mistake: nulled but not freed
 upon failure'''
  * ./raster/r.terraflow/unionFind.h:127 [error] - Common realloc mistake:
 "parent" nulled but not freed upon failure
  * ./raster/r.terraflow/unionFind.h:131 [error] - Common realloc mistake:
 "rank" nulled but not freed upon failure
  * ./vector/v.label.sa/labels.c:131 [error] - Common realloc mistake:
 "labels" nulled but not freed upon failure
 Modules: r.terraflow, v.label.sa
 thanks,
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1314>
