[GRASS-dev] NVIZ Error: Error of failed request: BadWindow
peter.loewe at gmx.de peter.loewe at gmx.de
Fri Mar 18 09:30:30 EDT 2011
Hi all,
I am building GRASS6.4 from source on a computation cluster. GRASS itself is up and running, but NVIZ causes trouble:
When invoking NVIZ from the GRASS command line (nviz -q), the NVIZ command window pops up and throws this error message:
Error of failed request:  BadWindow (invalid Window parameter)
  Major opcode of failed request:  3 (X_GetWindowAttributes)
  Resource id in failed request:  0xffffffff
  Serial number of failed request:  237
  Current serial number in output stream:  238
Any help/comment/advice would be much appreciated.
Peter
Dr. Peter Löwe
<peter.loewe at gmx.de>
NEU: FreePhone - kostenlos mobil telefonieren und surfen!
Jetzt informieren: http://www.gmx.net/de/go/freephone
