[GRASS-dev] NVIZ Error: Error of failed request: BadWindow
Maris Nartiss maris.gis at gmail.com
Fri Mar 18 11:41:24 EDT 2011
glxgears working fine?
OpenGL system vs NVIZ/OGSF compiled in OpenGL system?
export LIBGL_ALWAYS_INDIRECT=1 && nviz ?
Maris.
2011/3/18, peter.loewe at gmx.de <peter.loewe at gmx.de>:
> Hi all,
> I am building GRASS6.4 from source on a computation cluster. GRASS itself is
> up and running, but NVIZ causes trouble:
> When invoking NVIZ from the GRASS command line (nviz -q), the NVIZ command
> window pops up and throws this error message:
> Error of failed request:  BadWindow (invalid Window parameter)
>   Major opcode of failed request:  3 (X_GetWindowAttributes)
>   Resource id in failed request:  0xffffffff
>   Serial number of failed request:  237
>   Current serial number in output stream:  238
> Any help/comment/advice would be much appreciated.
> Peter
> Dr. Peter Löwe
> NEU: FreePhone - kostenlos mobil telefonieren und surfen!
> Jetzt informieren: http://www.gmx.net/de/go/freephone
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
