[GRASS-dev] Re: [GRASS GIS] #1149: WinGrass - load R-installation-path dynamically into PATH
GRASS GIS trac at osgeo.org
Fri Mar 18 14:41:05 EDT 2011
 Reporter:  hellik             |       Owner:  grass-dev@…
     Type:  enhancement        |      Status:  new
 Priority:  normal             |   Milestone:  7.0.0
Component:  Startup            |     Version:  svn-trunk
 Keywords:  wingrass, path, R  |    Platform:  MSWindows Vista
      Cpu:  x86-32             |
Comment(by hellik):
 Replying to [comment:3 hellik]:
 > I've attached instead a simple working bat-file to check dynamically if
 and where R is installed and added to the path.
 I've attached working patches for WinGrass64svn and WinGrass65.
 tested with a patched WinGrass6.4.1RC2, it's working now. R can be started
 within a WinGrass-text-mode-session.
 the ''improvement'' is that R is added to %PATH% dynamically instead of
 the actually very static approach which detects R only during wingrass-
 installation and, after installing new R-versions, it's not possible
 anymore to start a R-session within a wingrass-session because of the
 false path.
 any opinion for not adding it to grass65 and after some testing to
 grass64svn?
 Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1149#comment:4>
