[GRASS-dev] Compilation error on grass7-svn
Pierre Roudier pierre.roudier at gmail.com
Mon Mar 21 18:50:57 EDT 2011
Thanks for your pointers,
After a clean checkout and a make clean, it compiled successfully.
Cheers,
Pierre
2011/3/21 Glynn Clements <glynn at gclements.plus.com>:
> Pierre Roudier wrote:
>> I got the following error when compiling against the last update of
>> the grass7 trunk:
>> OBJ.x86_64-unknown-linux-gnu/strings.o -c strings.c
>> strings.c:136: error: conflicting types for �G_str_replace�
>> /usr/local/src/grass_trunk/dist.x86_64-unknown-linux-gnu/include/grass/gisdefs.h:580:
>> note: previous declaration of �G_str_replace� was here
>> Any suggestions?
> Are you running "make" from the top-level directory, or are you trying
> to compile just part of the tree?
> r45541 modified the prototype for G_str_replace() in both
> lib/gis/strings.c and include/gisdefs.h. Running "make" in the
> "include" directory should install the updated gisdefs.h file to
> dist.<arch>/include/grass/gisdefs.h, but this won't happen if you try
> to build the "lib" or "lib/gis" directories alone.
> In any case, running "make clean" first should fix the problem, even
> though it shouldn't be necessary.
> FWIW, the lines in question should be:
> include/gisdefs.h:580:
>        char *G_str_replace(const char *, const char *, const char *);
> (and also for dist.<arch>/include/grass/gisdefs.h).
> lib/gis/strings.c:136:
>        char *G_str_replace(const char *buffer, const char *old_str, const char *new_str)
Scientist
Landcare Research, New Zealand
