[GRASS-dev] [GRASS GIS] #1331: winGrass: hangs when displaying vector attribute labels
GRASS GIS trac at osgeo.org
Mon Mar 21 22:04:15 EDT 2011
 Reporter:  morrisxs09  |       Owner:  grass-dev@…
     Type:  defect      |      Status:  new
 Priority:  normal      |   Milestone:  6.4.1
Component:  Display     |     Version:  6.4.1 RCs
 Keywords:  wingrass    |    Platform:  MSWindows XP
      Cpu:  x86-32      |
 Using the spearfish dataset, add the vector map archsites.
 In the Layer Manager, click on archsites to open the properties window.
 In the Required Tab tick 'Display selected attribute based on attrcol'
 In the Labels Tab choose 'str1' in the Name of field to be displayed.
 Apply changes - winGrass windows hang; no labels are displayed; only
 option is to close all winGrass windows and re-start winGrass.
 Using d.vect to display attribute labels via the wxgui command line option
 also results in winGrass hanging.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1331>
