[GRASS-dev] NVIZ Error: Error of failed request: BadWindow
"Peter Löwe" peter.loewe at gmx.de
Tue Mar 22 06:42:58 EDT 2011
Hi Maris,
export LIBGL_ALWAYS_INDIRECT=1
did the trick.
Thanks,
Peter
-------- Original-Nachricht --------
> Datum: Fri, 18 Mar 2011 17:41:24 +0200
> Von: Maris Nartiss <maris.gis at gmail.com>
> An: peter.loewe at gmx.de
> CC: grass-dev at lists.osgeo.org
> Betreff: Re: [GRASS-dev] NVIZ Error: Error of failed request: BadWindow
> glxgears working fine?
> OpenGL system vs NVIZ/OGSF compiled in OpenGL system?
> export LIBGL_ALWAYS_INDIRECT=1 && nviz ?
> Maris.
> 2011/3/18, peter.loewe at gmx.de <peter.loewe at gmx.de>:
> > Hi all,
> > I am building GRASS6.4 from source on a computation cluster. GRASS
> itself is
> > up and running, but NVIZ causes trouble:
> > When invoking NVIZ from the GRASS command line (nviz -q), the NVIZ
> command
> > window pops up and throws this error message:
> > Error of failed request:  BadWindow (invalid Window parameter)
> >   Major opcode of failed request:  3 (X_GetWindowAttributes)
> >   Resource id in failed request:  0xffffffff
> >   Serial number of failed request:  237
> >   Current serial number in output stream:  238
> > Any help/comment/advice would be much appreciated.
Dr. Peter Löwe
NEU: FreePhone - kostenlos mobil telefonieren und surfen!
Jetzt informieren: http://www.gmx.net/de/go/freephone
