[GRASS-dev] text interface for GRASS70
Martin Landa landa.martin at gmail.com
Wed Mar 23 05:44:19 EDT 2011
2011/3/23 Glynn Clements <glynn at gclements.plus.com>:
>> > > $ grass70 -c /home/martin/grassdata/test1
>> > > g.proj -p
>> > > XY location (unprojected)
>> create XY by default? I'm not so sure about that. I'd think it
>> much better to exit with an error if location type could not be
>> determined.
> The most important thing is to create /something/ so that you can
> actually get into GRASS. Once you've done that, you can change the
> projection or create a new location with g.proj. But first you have to
> get to the point that g.proj works.
Agreed.
>> > > $ grass70 -c ~/lakes.shp /home/martin/grassdata/test1
>> > in r45727 you can also create new location based on EPSG
>> > $ grass70 -c EPSG:4326 /home/martin/grassdata/test1
>> re. -c, in GRASS 6 we have been using the -c command line flag
>> to create a new mapset if it doesn't exist. Using the same
>> flag contextually to create a new location too would be confusing
>> and bug prone. We should split mapset/location creation into
>> two separate flags.
> The argument is a complete path, so the logical approach would be to
> check how much of that path already exists, i.e.:
should be working like this
>        if the complete path exists:
>            mapset already exists; no need to create anything
$ grass70 -c /home/martin/grassdata/nc_spm_08/user1/
works
>        else if the path minus the last element exists:
>            location exists; create new mapset
$ grass70 -c /home/martin/grassdata/nc_spm_08/user2
works
>        else if the path minus the last two elements exists:
>            database exists; create new location and mapset
current behaviour
grass70 -c /home/martin/grassdata/test01/user
creates location 'user' in dbase '/home/martin/grassdata/test01'
I am not sure at this point, to change this behaviour you would need
to define always the mapset, e.g.
grass70 -c /home/martin/grassdata/test01/PERMANENT
which is annoying.
>        else
>            none of it exists; create new database, location and mapset
works.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
