[GRASS-dev] text interface for GRASS70
Pierre Roudier pierre.roudier at gmail.com
Wed Mar 23 18:33:43 EDT 2011
Martin,
Thanks very much for your help. That solved my problem.
Cheers,
Pierre
FYI:
pierrer at grass:~$ unset GISBASE
pierrer at grass:~$ grass70 -c EPSG:4326 /home/pierrer/grassdata/test2
WELCOME TO GRASS 7.0.svn (2011)
   1) Have at your side all available GRASS tutorials
   2) When working on your location, the following materials
      are extremely useful:
      - A topo map of your area
      - Current catalog of available computer maps
   3) Check the GRASS webpages for feedback mailinglists and more:
      http://grass.osgeo.org
      http://www.grass-gis.org
Hit RETURN to continue
Starting GRASS GIS...
WARNING: It appears that the X Windows system is not active.
A graphical based user interface is not supported.
Switching to text based interface mode.
          __________  ___   __________    _______________
         / ____/ __ \/   | / ___/ ___/   / ____/  _/ ___/
        / / __/ /_/ / /| | \__ \\_  \   / / __ / / \__ \
       / /_/ / _, _/ ___ |___/ /__/ /  / /_/ // / ___/ /
       \____/_/ |_/_/  |_/____/____/   \____/___//____/
Welcome to GRASS 7.0.svn (2011)
GRASS homepage:                          http://grass.osgeo.org
This version running through:            Bash Shell (/bin/bash)
Help is available with the command:      g.manual -i
See the licence terms with:              g.version -c
Start the GUI with:                      g.gui wxpython
When ready to quit enter:                exit
GRASS 7.0.svn (test2):~ > g.proj -p
-PROJ_INFO-------------------------------------------------
proj       : ll
datum      : wgs84
ellps      : wgs84
no_defs    : defined
-PROJ_UNITS------------------------------------------------
unit       : degree
units      : degrees
meters     : 1.0
2011/3/24 Martin Landa <landa.martin at gmail.com>:
> Hi,
> 2011/3/23 Pierre Roudier <pierre.roudier at gmail.com>:
>> pierrer at grass:~$ export GISBASE=""
> unset GISBASE
> Martin
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
Scientist
Landcare Research, New Zealand
