[GRASS-dev] Re: [GRASS GIS] #1286: clean_temp can not be called before LCATION_NAME is set
GRASS GIS trac at osgeo.org
Fri Mar 25 01:18:29 EDT 2011
 Reporter:  marisn       |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  critical     |   Milestone:  6.4.1
Component:  Startup      |     Version:  6.4.1 RCs
 Keywords:  wingrass     |    Platform:  MSWindows Vista
      Cpu:  Unspecified  |
Comment(by hamish):
 Replying to [comment:4 martinl]:
 > Replying to [comment:3 marisn]:
 > > All three places of clean_tmp can be reached without LOCATION_NAME
 being set.
 http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/lib/init/init.ba
 > On which conditions? Seems to work here without any problem.
 try removing the %HOME%/.grassrc6 file or installing on a fresh system/VM.
 And/or cancel after initial startup with a new .grassrc6 file containing
 location (etc) set to <UNKNOWN>, then restart.
 Or delete/rename the GISDBASE, LOCATION, or MAPSET dir which happens to be
 the last one used.
 The .bat file just checks that the rc file exists in %HOME%, not that it
 contains valid entries, and if it's the same as init.sh, the operational
 version used by G_*() isn't the one in $HOME anyway.
 I'm not sure if init.sh is terribly better about it checking validity, but
 the question is if it creates a fatal script exit in the WinGrass startup,
 while a similar problem would just create a harmless error message to the
 console on UNIX.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/1286#comment:7>
