[GRASS-dev] Re: [GRASS GIS] #192: ps.map: geogrid RGB color and ellipsoid
GRASS GIS trac at osgeo.org
Fri Mar 25 02:40:59 EDT 2011
 Reporter:  hamish                        |       Owner:  grass-dev@…
     Type:  enhancement                   |      Status:  new
 Priority:  trivial                       |   Milestone:  6.5.0
Component:  Ps.map                        |     Version:  svn-trunk
 Keywords:  ps.map geogrid ellipsoid RGB  |    Platform:  Unspecified
      Cpu:  Unspecified                   |
Comment(by annakrat):
 Replying to [ticket:192 hamish]:
 > Hi,
 > ps.map's geogrid command only accepts named colors currently. it should
 be updated to accept R:G:B as well.
 > Also it is unclear to me which ellipsoid geogrid uses. I suspect it is
 the current one, which is fine, but it would be nice to add an option to
 use WGS84's instead, like "d.grid -w".
 > thanks
 > Hamish
 > ps- can we have "ps.map" added to the trac Component drop down list?
 R:G:B is not supported by other commands, too. Mapinfo (color, background,
 border) and vlegend (border) are supported by the new GUI, so they should
 be fixed first.
 Other commands which accept only named colors are: grid, geogrid, header,
 outline, setcolor. GUI does't support them yet, so these can wait.
 Thanks
 Anna
Ticket URL: <http://trac.osgeo.org/grass/ticket/192#comment:3>
