[GRASS-dev] Re: [GRASS GIS] #1310: Browse button in WxPython GUIs (for scripts) does not provide a correct file path for WinGRAS
GRASS GIS trac at osgeo.org
Sat Mar 26 10:01:42 EDT 2011
 Reporter:  katrineggert1980  |       Owner:  grass-dev@…
     Type:  defect            |      Status:  new
 Priority:  critical          |   Milestone:  6.4.1
Component:  wxGUI             |     Version:  6.4.1 RCs
 Keywords:  winGRASS          |    Platform:  MSWindows XP
      Cpu:  Unspecified       |
Comment(by hellik):
 tested with WinGRASS-6.4.SVN-r45749-1-Setup.exe
 folder and file destination of the output files always definded by the
 Browse button of the wxgui
 r.out.xyz input=elevation at PERMANENT output=C:\wd\exportgrass\routxyz.txt
 c:/Program Files/GRASS 6.4.SVN/scripts/r.out.xyz: line 61:
 C:wdexportgrassroutxyz.txt: Permission denied
 but very interesting also tested with other raster and vector export
 modules
 r.out.ascii input=elevation at PERMANENT
 output=C:\wd\exportgrass\routascii.asc
 (Sat Mar 26 14:43:54 2011) Command finished (10 sec)
 r.out.arc input=elevation at PERMANENT output=C:\wd\exportgrass\routarc.asc
 (Sat Mar 26 14:46:38 2011) Command finished (12 sec)
 r.out.mat input=elevation at PERMANENT output=C:\wd\exportgrass\routmat.mat
 r.out.mat komplett.
 (Sat Mar 26 14:48:06 2011) Command finished (1 sec)
 r.out.png input=elevation at PERMANENT output=C:\wd\exportgrass\routpng.png
 (Sat Mar 26 14:49:23 2011) Command finished (3 sec)
 r.out.ppm input=elevation at PERMANENT output=C:\wd\exportgrass\routppm.ppm
 Zeilen = 1350, Spalten = 1500
 Konvertiere ...
 r.out.ppm komplett. Datei <C:\wd\exportgrass\routppm.ppm> erstellt.
 (Sat Mar 26 14:50:15 2011) Command finished (2 sec)
 r.out.gdal input=elevation at PERMANENT
 output=C:\wd\exportgrass\routgdal.gtif
 Exportiere in den GDAL-Datentyp: Float32
 Prüfe GDAL Datentyp und NoData-Wert.
 ERROR 6: SetColorTable() only supported for Byte or UInt16
 bands in TIFF format.
 Exportiere nach GDAL-Raster.
 r.out.gdal komplett.
 (Sat Mar 26 14:52:23 2011) Command finished (1 sec)
 v.out.ascii input=firestations at PERMANENT
 output=C:\wd\exportgrass\voutascii.txt
 (Sat Mar 26 14:53:32 2011) Command finished (0 sec)
 v.out.dxf input=firestations at PERMANENT
 output=C:\wd\exportgrass\voutdxf.dxf
 v.out.dxf komplett. 71 Feature geschrieben nach
 'C:\wd\exportgrass\voutdxf.dxf'.
 (Sat Mar 26 14:54:27 2011) Command finished (0 sec)
 are you able to test it on your side?
 best regards
 Helmut
Ticket URL: <http://trac.osgeo.org/grass/ticket/1310#comment:1>
