[GRASS-dev] Re: [GRASS GIS] #1310: Browse button in WxPython GUIs (for scripts) does not provide a correct file path for WinGRAS
GRASS GIS trac at osgeo.org
Sat Mar 26 13:34:53 EDT 2011
 Reporter:  katrineggert1980  |       Owner:  grass-dev@…
     Type:  defect            |      Status:  new
 Priority:  critical          |   Milestone:  6.4.1
Component:  wxGUI             |     Version:  6.4.1 RCs
 Keywords:  winGRASS          |    Platform:  MSWindows XP
      Cpu:  Unspecified       |
Comment(by hellik):
 Replying to [comment:4 neteler]:
 > Helmut, could you please test if adding output="$GIS_OPT_OUTPUT" helps?
 tried with following:
 # if no output filename, output to stdout
 if  [ -z "$GIS_OPT_OUTPUT" ] || [ "$GIS_OPT_OUTPUT" = "-" ]; then
     r.stats -1gn "$GIS_OPT_INPUT" fs="$GIS_OPT_FS"
 else
     r.stats -1gn "$GIS_OPT_INPUT" fs="$GIS_OPT_FS" >
 fi
 now there isn't any error message
 r.out.xyz input=elevation at PERMANENT output=C:\wd\test\routxyzp.xyz
 (Sat Mar 26 18:30:37 2011) Command finished (46 sec)
 '''but''' the file doesn't seem to be written, the destination folder is
 empty.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1310#comment:5>
