[GRASS-dev] Re: [GRASS GIS] #1310: Browse button in WxPython GUIs (for scripts) does not provide a correct file path for WinGRAS
GRASS GIS trac at osgeo.org
Sat Mar 26 14:34:24 EDT 2011
 Reporter:  katrineggert1980  |       Owner:  grass-dev@…
     Type:  defect            |      Status:  new
 Priority:  critical          |   Milestone:  6.4.1
Component:  wxGUI             |     Version:  6.4.1 RCs
 Keywords:  winGRASS          |    Platform:  MSWindows XP
      Cpu:  Unspecified       |
Comment(by hellik):
 Replying to [comment:7 hellik]:
 > Replying to [comment:6 neteler]:
 > > Yes, you forgot to take out ">". Try this code:
 > r.out.xyz input=elevation at PERMANENT output=C:\wd\test\test.xyz
 > ERROR: Kann Datei <C:wdtesttest.xyz> nicht zum Schreiben öffnen.
 > (Sat Mar 26 19:14:10 2011) Command finished (0 sec)
 > so no change regarding the path issue.
 for the record with the original code:
 if I copy the command from the wxgui to the wingrass-msys-shell
 GRASS 6.4> r.out.xyz input=elevation at PERMANENT
 output=C:\wd\test\testroutxyz.txt
 c:/Program Files/GRASS 6.4.SVN/scripts/r.out.xyz: line 61:
 C:wdtesttestroutxyz.txt: Permission denied
 and with a quoted path in the wingrass-msys-shell
 output="C:\wd\test\testroutxyz.txt"
  100%
 GRASS 6.4>
 the original code is working in windows with a quoted path
Ticket URL: <http://trac.osgeo.org/grass/ticket/1310#comment:8>
