[GRASS-dev] Re: parsing file paths in GRASS Scripts- Windows OS
Markus Neteler neteler at osgeo.org
Sat Mar 26 15:43:46 EDT 2011
On Sat, Mar 26, 2011 at 8:09 PM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> katrin eggert wrote:
>> Just a preliminary note: This error is reported here:
>> http://lists.osgeo.org/pipermail/grass-dev/2011-March/053774.html
>> I saw that Glynn sugeste this a couple of months ago:
>> http://lists.osgeo.org/pipermail/grass-dev/2010-October/052396.html
>> Can this be an option to solve this problem? Can anyone give a few tips on
>> this? (just to try and test it)
> Right. Currently, 6.5 has utils.split(), which handles Windows
> filenames, but much of the wx GUI is still using shlex.split()
> directly.
> Feel free to replace all occurrences of shlex.split() with
> utils.split() in your local copy. Also, open a bug report (if there
> isn't already one for this issue).
Here a silly two-line for most of the job:
cd gui/wxpython/gui_modules/
for i in menuform.py gmodeler.py menu.py prompt.py goutput.py ; do mv
$i tmp.py ; cat tmp.py | sed 's+shlex.split+utils.split+g' > $i ; rm
-f tmp.py ; done
$i tmp.py ; cat tmp.py | sed 's+import shlex+import utils+g' > $i ; rm
-f tmp.py ; done
I hesitate to submit this since a my wx fu is not high enough to verify
but the GUI starts.
Markus
