[GRASS-dev] Re: [GRASS GIS] #1126: 3D view crashing when started with vector data (was: 3D view crashing)
GRASS GIS trac at osgeo.org
Sat Mar 26 21:29:14 EDT 2011
 Reporter:  pobsteta   |       Owner:  grass-dev@…
     Type:  defect     |      Status:  new
 Priority:  critical   |   Milestone:  7.0.0
Component:  wxGUI      |     Version:  svn-trunk
 Keywords:  wxNviz     |    Platform:  MacOSX
      Cpu:  OSX/Intel  |
Changes (by helena):
  * cpu:  x86-64 => OSX/Intel
Comment:
 More details about this for trunk compiled March 26, 2011:
 entire wxGUI crashes after adding vector points or lines, it gives the
 following error when trying to switch to 3D view
 with both elevation and vector layer selected (using nc_spm data set, I
 had elevation and point firestations
 in map layers list, but it gives the error for line vector busroutes as
 well)
 (Traceback - no module named adw.advancedsplash)
 v.info <t> is not a valid flag
 is it trying to run v.info -t?
Ticket URL: <http://trac.osgeo.org/grass/ticket/1126#comment:5>
