[GRASS-dev] Re: [GRASS GIS] #192: ps.map: geogrid RGB color and ellipsoid
GRASS GIS trac at osgeo.org
Sun Mar 27 04:31:27 EDT 2011
 Reporter:  hamish                        |       Owner:  hamish
     Type:  enhancement                   |      Status:  assigned
 Priority:  normal                        |   Milestone:  6.5.0
Component:  Ps.map                        |     Version:  svn-trunk
 Keywords:  ps.map geogrid ellipsoid RGB  |    Platform:  Unspecified
      Cpu:  Unspecified                   |
Comment(by annakrat):
 Replying to [comment:5 hamish]:
 > RGB support added to mapinfo in 6.5&7 in r45774,5.
 > RGB support added to vlegend in 6.5&7 in r45776,7.
 Thanks, I made the correction you suggested (use named color in the
 instruction file if possible).
 > example showing mapinfo background working just until
 > the point where the mapinfo box does not overlap the
 > main map box: (change y=6.45 to 6.50 to see it fall off the edge)
 I know about this, I suppose this behaviour is a bug. I forgot to mention
 it.
 Anna
Ticket URL: <http://trac.osgeo.org/grass/ticket/192#comment:6>
