[GRASS-dev] Error with r.to.vect- Solved?
António Rocha antonio.rocha at deimos.com.pt
Tue Mar 29 05:06:24 EDT 2011
Hello Markus
Unfortunely, I get this error when I run other datasets. In this case, a
landCover with all CELLS and spatial resolution of 30. The problem is
that North carolina sample is too small.
r.to.vect -v input=FULL at PERMANENT output=FULL feature=area
I get this:
Default driver / database set to:
driver: dbf
database: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
Extracting areas...
Building topology for vector map <PT_National_2000_FULL>...
R4243000ERROR: G_realloc: unable to allocate 16976004 bytes at
struct_alloc.c:133
It has created a vector but I cannot display and I cannot use v.info (it
says that I need to build topology).
And If I try to build topology I get and error and before this warning:
Coor files of vector map <PT_National_2000_FULL at PERMANENT> is larger
than it should be (241464079 bytes excess)
So my questions are:
1- Is any fix for this?
2- If not, is there any defined limit for a raster in order to be
converted to vector?
Thanks
Antonio
Markus Neteler wrote:
> 2011/3/23 António Rocha <antonio.rocha at deimos.com.pt>:
>> A couple of months ago I sent a few messages regarding a memorry error with
>> r.to.vect (it was allocating to many information and data). My question is,
>> sicne r.to.vect was not updated, is there any raster or vector lib update
>> that had any impact on this?
> Did you post a test case? Best done with the North Carolina sample
> data set. Otherwise it is hard to replicate...
> Markus
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5995 (20110329) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
