[GRASS-dev] g.extension does not find any extension to install
Pierre Roudier pierre.roudier at gmail.com
Wed Mar 30 19:27:47 EDT 2011
Thanks Markus,
Unfortunately, I still have the same behaviour after exporting my
proxy settings to the HTTPS_PROXY envvar:
GRASS 7.0.svn (NZTM2000):~ > g.extension -l
svnurl=https://svn.osgeo.org/grass/grass-addons
Fetching list of modules from GRASS-Addons SVN (be patient)...
I'm wondering if I have to specify something special for https in my
subversion conf file?
Pierre
2011/3/30 Markus Neteler <neteler at osgeo.org>:
> On Wed, Mar 30, 2011 at 3:13 AM, Pierre Roudier
> <pierre.roudier at gmail.com> wrote:
>> Hi,
>> No add-on seems to9 be available to my system when trying to use the
>> g.extension command:
>> Therefore, it is not possible to install any:
>> GRASS 7.0.svn (NZTM2000):~ > g.extension -s
>> svnurl=https://svn.osgeo.org/grass/grass-addons extension=wx.psmap
>> Fetching 'wx.psmap' from GRASS-Addons SVN (be patient)...
>> svn: URL 'https://svn.osgeo.org/grass/grass-addons/wx/wx.psmap' doesn't exist
>> ERROR: GRASS Addons 'wx.psmap' not found in repository
>> If that's of any use, I'm running the last grass70 SVN version, on a
>> Linux x86_64 platform. But I suspect this is related to the proxy of
>> my institute, despite I got it specified in the HTTP_PROXY envvar, and
>> in my ~/.subversion/servers file.
> I think that you also need to set the HTTPS proxy variable:
> https_proxy=http://username:password@host:port/
> export https_proxy
> Markus
Scientist
Landcare Research, New Zealand
