[GRASS-dev] [GRASS GIS] #1355: Error starting wxpython v.digit session
GRASS GIS trac at osgeo.org
Tue May 3 10:37:05 EDT 2011
 Reporter:  epatton  |       Owner:  grass-dev@…
     Type:  defect   |      Status:  new
 Priority:  normal   |   Milestone:  6.5.0
Component:  wxGUI    |     Version:  svn-develbranch6
 Keywords:  v.digit  |    Platform:  Linux
      Cpu:  x86-32   |
 This error is printed to the Layer Manager output window when I try to
 start editing an existing vector. I select "Digitize" from the drop-down
 box on the Map Display, and then select the name of my vector under the
 left-most drop-down box in the Map Display. The Map Display doesn't draw
 any of my GIS layers, but goes completely white at this point.
 I have rebuilt the vector topology, but the error still occurs. I have
 tested the wxgui digitizer in a different mapset with a different vector,
 with the same error occurring.
 ~ Eric.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1355>
