[GRASS-dev] [GRASS GIS] #1359: No Startup
GRASS GIS trac at osgeo.org
Tue May 10 02:04:29 EDT 2011
#1359: No Startup
 Reporter:  ke6iyc     |       Owner:  grass-dev@…
     Type:  defect     |      Status:  new
 Priority:  normal     |   Milestone:
Component:  Startup    |     Version:  6.4.0
 Keywords:             |    Platform:  MacOSX
      Cpu:  OSX/Intel  |
 GRASS (Latest download) will not start.
 Full text of terminal session follows:
 Last login: Mon May  9 22:56:18 on ttys000
 '/Applications/GRASS-6.4.app/Contents/MacOS/grass.sh'; exit
 You have new mail.
 brian-gieryks-macbook-pro-3:~ ke6iyc$
 Rebuilding Addon HTML manual pages index...
 Rebuilding Addon menu...
 Python 2.6.1 found.
 WELCOME TO GRASS              Version 6.4.1         2011
    1) Have at your side all available GRASS tutorials
    2) When working on your location, the following materials
       are extremely useful:
       - A topo map of your area
       - Current catalog of available computer maps
    3) Check the GRASS webpages for feedback mailinglists and more:
       http://www.grass-gis.org
       http://grass.osgeo.org
 Hit RETURN to continue
 Starting GRASS ...
   File
 "/Applications/GRASS-6.4.app/Contents/MacOS/etc/wxpython/gis_set.py", line
 34, in <module>
     from gui_modules import globalvar
   File "/Users/Shared/src/GRASS/grass-6.4.1-snow/dist.i386-apple-
 darwin10.7.0/etc/wxpython/gui_modules/globalvar.py", line 79, in <module>
   File "/Users/Shared/unix/wxpython-snow/lib/python2.6/site-
 packages/wx-2.8-mac-unicode/wx/__init__.py", line 45, in <module>
 packages/wx-2.8-mac-unicode/wx/_core.py", line 4, in <module>
 ImportError:
 dlopen(/Applications/GRASS-6.4.app/Contents/MacOS/etc/python/wx/_core_.so,
 2): Library not loaded:
 /Library/Frameworks/UnixImageIO.framework/Versions/C/UnixImageIO
   Referenced from:
 /Applications/GRASS-6.4.app/Contents/MacOS/lib/libwx_macud-2.8.0.dylib
   Reason: image not found
 Error in GUI startup. If necessary, please
 report this error to the GRASS developers.
 Switching to text mode now.
 Hit RETURN to continue...
 dyld: Library not loaded:
 /Library/Frameworks/GDAL.framework/Versions/1.8/GDAL
   Referenced from:
 /Applications/GRASS-6.4.app/Contents/MacOS/lib/libgrass_gis.dylib
 /Applications/GRASS-6.4.app/Contents/MacOS/etc/Init.sh: line 630: 12084
 Trace/BPT trap          "$ETC/set_data"
 logout
 [Process completed]
Ticket URL: <http://trac.osgeo.org/grass/ticket/1359>
