[GRASS-dev] grass7: problem --with-liblas
Martin Landa landa.martin at gmail.com
Tue May 31 04:00:47 EDT 2011
I have compiled liblas from the repo [1] and then grass7 with
`--with-liblas`, unfortunately without success
configure:6544: checking for liblas-config
configure:6599: gcc -o conftest -g -Wall
-Werror-implicit-function-declaration -fno-common -Wextra -Wunused
-Wl,--export-dynamic conftest.c  -L/usr/local/lib -llas -llas_c
-L/usr/lib optimized;/usr/lib/libboost_program_options-mt.so;debug;/usr/lib/libboost_program_options-mt.so
1>&5
gcc: error: optimized;/usr/lib/libboost_program_options-mt.so;debug;/usr/lib/libboost_program_options-mt.so:
No such file or directory
configure: failed program was:
#line 6592 "configure"
#include "confdefs.h"
#include <liblas/capi/liblas.h>
int main() {
LASReader_Create("foo");
; return 0; }
having
$ gcc --version
gcc (Debian 4.6.0-10) 4.6.1 20110526 (prerelease)
$ liblas-config --libs
-L/usr/local/lib -llas -llas_c -L/usr/lib
Any hint? Martin
[1] http://liblas.org/compilation.html#using-unix-makefiles-on-linux
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
