[GRASS-dev] help porting GRASS-RaPlaT to GRASS7
Fri Nov 4 04:56:07 EDT 2011
Dylan Beaudette wrote:
> however my futile attempt has resulted in a segfault. The tail end
> of which looks like:
> Any tips?
Compile with debug info and without optimisation:
	make clean
	make CFLAGS=-g &> build.log
Pay attention to any warnings which are generated.
Run the program under gdb; when it segfaults, you can view the call
stack with "bt" (or "bt full" to see arguments). The top-most entry
will be the source line where the segfault occurred.
