[GRASS-dev] Re: [GRASS-SVN] r49122 - grass/branches/develbranch_6/include/Make
Hamish hamish_b at yahoo.com
Tue Nov 8 02:38:53 EST 2011
Hamish:
> > yeah but the change before it most probably just broke *all* man page
> > building for a regular fresh full build(!)... (I didn't try, but it is
> > wrong, so "probably"..)
Martin:
> of course I have tried that before I committed this change,
> nothing was broken!
shrug. did you distclean?
$(MODULE_TOPDIR)/tools/g.html2man when MODULE_TOPDIR="." as in the case
of a regular build points to a directory not a script.  can't be executed.
--unless you override the MODULE_TOPDIR setting like g.extension does.
> BTW, similar change has been done in trunk few months ago,
> nobody complained till now.
g.html2man.py in trunk is installed in a completely different manner
and coded to run from a different directory variable. they're not really
comparable.
> As result g.extension *doesn't* work again, as I said.
only when grass was run from $source/dist.x86../.  For users who had
run 'make install' or installed from a package it should have been ok.
> No time to fix it again, I will leave it for you.
try r49126. (devbr6)
regards,
Hamish
