[GRASS-dev] Re: [GRASS GIS] #1488: v.in.dxf wrapper not working
GRASS GIS trac at osgeo.org
Sat Nov 12 10:48:26 EST 2011
 Reporter:  cmbarton     |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  wxGUI        |     Version:  svn-trunk
 Keywords:  v.in.dxf     |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by cmbarton):
 After a bit of testing, using 'ignore' works, but 'replace' creates
 further errors down the line
   File "/Applications/GRASS/GRASS-7.0.app/Contents/MacOS/etc
 /python/wx/lib/filebrowsebutton.py", line 140, in OnChanged
 self.changeCallback(evt)
 /gui/wxpython/gui_modules/gdialogs.py", line 1962, in
 OnSetDsn
 grassName = utils.GetValidLayerName(layerName)
 /gui/wxpython/gui_modules/utils.py", line 171, in
 GetValidLayerName
 retName = str(name).strip()
 UnicodeEncodeError
 'ascii' codec can't encode character u'\ufffd' in position
 0: ordinal not in range(128)
 Unless there is a compelling reason to do otherwise, I suggest using
 'ignore'. Thanks for the insight Glynn.
 Also, since the "string" module is imported, using "string" as a variable
 name in a method so as to produce a code line like
 string.decode(enc)
 seems potentially confusing to those reading the code at least, and
 potentially to the program. Maybe the variable should be changed to "str"
 or something along that line.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1488#comment:7>
