[GRASS-dev] Re: [GRASS GIS] #1488: v.in.dxf wrapper not working
GRASS GIS trac at osgeo.org
Sun Nov 13 16:17:19 EST 2011
 Reporter:  cmbarton     |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  wxGUI        |     Version:  svn-trunk
 Keywords:  v.in.dxf     |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by glynn):
 Replying to [comment:12 cmbarton]:
 > Changing !EncodeString to use replace does not work. There is still the
 same error reported above.
 That's because utils.!GetValidLayerName() just uses str() rather than
 !EncodeString() or similar. str() uses the default encoding (not the
 locale's encoding), which is usually ASCII. And (AFAICT) it uses the
 equivalent of errors='strict', so that needs to be fixed regardless of how
 !DecodeString() behaves. Otherwise, you'll get a similar error for any
 non-ASCII character.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1488#comment:13>
